Hi Everyone, I have been watching some videos on YouTube and practicing my electronics skills. I wanted to try and fix an old Sony laptop I have. I think the LCD Inverter is bad from the original machine. I have been unable to locate an exact replacement so I thought I would try a generic inverter and this is where I am at.
The laptop works with an external VGA screen. It is a Sony Vaio PCG-F690 from around the year 2000. It is a P3 850, 128MB RAM, with an ATI Rage mobility. I though it would be a fun Windows 98 machine and would make for a good project to move up in my beginner status.
The laptop screen just died one day. As a result this system has been sitting in storage for years. If the original inverter is installed the screen shows no signs of life. Using my meter I can measure the input voltages at the inverter.
My original inverter has 5 pins. Voltage In (16 V), Drive (5V), Contrast, Brightness, Ground. The new board has 4 pins. Voltage In (5-28VDC), Drive (0-1 volt off, 2-5 volts on), Brightness, Ground. I soldered the wires from the laptop lcd cable to the inverter. My monitor will now turn on white but I can't see anything else. During the laptop boot the screen will go dark for a second before it redraws to white. Originally I had VCC, Drive, Brightness, Ground. I moved the Brightness wire to contrast. That made the layout VCC, Drive, Contrast, Ground. Both results are the same. If I do not connect either brightness or contrast the screen remains dark.
1 - Can a generic inverter be used?
2 - Am I going about this project the wrong way?
3 - Does anyone know where I might get another generic CCFL driver that has 5 inputs?
I need to know what to research or read to get me moving on the right path.
Edit - I found the forum post for some good beginner materials and will start looking there.
