Author Topic: RC Low Pass Filter help  (Read 1410 times)
Offline sanyoboyTopic starter
« on: January 22, 2016, 03:07:55 am »
Hi Guys, I made a RC low pass filter to place on the line into my sub woofer amp but I don't think its working, sounds no different than with no RC Low pass filter.
My setup is PC > karaoke mic amp to left and right speakers + steal Left channel for sub > circuit > amp > sub woofer.
Here's a picture.
The circles are RCA female connectors.
I am using a 100v 15uF cap it has no polarity marking what so ever. Only writing with capacitance the company and the voltage on one side. I am using the side with no writing as positive. It hasn't blown yet so I am guessing its right or just not passing any audio hence its not working.
Is it my capacitor backward or is it the fact its coming out of a karaoke mic amp or something else?
Offline MrSlack
Re: RC Low Pass Filter help
« Reply #1 on: January 22, 2016, 06:55:48 am »
Bit hacky but that may work. I've done similar things in the past. The 3db point of that filter is ~88Hz but there a couple of issues with it. Firstly the roll off is still pretty slow on a simple RC filter and at low frequencies that may not be audible. You can improve that by using two or more identical filters one after the other or picking a different filter model (twin-t etc). Note that as each stage operates as a divider, the output will reduce considerably! Secondly the thing will modify the impedance of the source considerably so it may merely reduce the volume and crush any noticable filter effects; use an active filter (op amp) for each stage. Probably a tl072 can be run single rail in an active filter config off a 9v battery for this job without causing any nasty side effects as it's consumer line level.
Edit: just to add, back in the summer of 1992 I built two active speakers using the same method instead of crossover networks. Still work today and sound rather good!
« Last Edit: January 22, 2016, 07:02:20 am by MrSlack »
Offline Zero999
  • 0999
« Reply #2 on: January 22, 2016, 08:55:55 am »
What's the cut-off frequency?
