Author Topic: Strange analog readings.  (Read 2475 times)
Offline cameronasmithTopic starter
« on: April 07, 2014, 07:10:23 pm »
Hi Guys,
I have an INA125 plugged into a breadboard (i read that this might be a problem) with a strain gauge connected to an Arduino analog pin.
When I take readings it seems to jump around. For example:
101, 102, 101, 101, 102, 101, 101, 101.
Is this normal for a strain gauge? And can anyone recommend a way to not make the signals so erratic.
Thanks,
Cameron.
Offline PA0PBZ
Re: Strange analog readings.
« Reply #1 on: April 07, 2014, 07:13:03 pm »
I don“t see a problem here: imagine that the signal is 101.5, what readout would you suspect?
« Reply #2 on: April 07, 2014, 07:19:08 pm »
Hi, paopbz,
I'm sorry, I don't think I explained it very well. If I put a 100gram weight on the scale. The reading will jump around like:
202, 201, 201, 202, 202, 201.
If I put a 101 gram weight on the scale I will get something like this:
203, 202, 203, 203, 203, 202.
You can see how this can become a problem when weighing in 1 gram increments.
I really need it to just give me one reading.
Thanks,
Cameron.
Offline KJDS
    • my website holding page
« Reply #3 on: April 07, 2014, 07:44:04 pm »
You will always have some variation due to noise.
Just display an average.
Offline lewis
  • Nullius in verba
« Reply #4 on: April 07, 2014, 07:47:46 pm »
You need some digital averaging! I use an IIR filter like this: http://electronics.stackexchange.com/questions/30370/fast-and-memory-efficient-moving-average-calculation
Think about why the reading will jump around and why you will never get a single consistent value.
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline PA0PBZ
« Reply #5 on: April 07, 2014, 08:03:47 pm »
Hi, paopbz,
I think you did explain it very well, just look at my answer again and think about it...
Offline kfitch42
« Reply #6 on: April 07, 2014, 08:56:43 pm »
Expanding on the concept a bit more, this is a case were noise can be a good thing. By using an average you can get a more precise reading than what you get with a single reading.
Think about those cheap digital oral thermometers, they can take quite a while to give a reading ... but the ones they use at the doctor's office only take a couple seconds.
This is because the cheap ones are using a cheaper/noisier sensor and wait until the average settles down. The more expensive ones at the doctor's office use a better(more expensive) sensor so they don't have to average for so long.
