I hope you have only shown part of your code. There is a lot missing.
From what you have shown, I doubt your code is running.
- MPLAB X and XC8???
- More consistent format will help readability.
- Add configuration bits.
I use: "Window -> Target Memory Views -> Configuration Bits" within MPLAB X
- Add #define _XTAL_FREQ 8000000L in order for __delay_ms() to work.
- Select "internal osc" in OSCCON = 0b01110010; statement.
It is good practice to always include leading zeros if you use the binary definition to avoid errors.
- Don't enable interrupts before initialization is complete.
Move interrupt enable to just before main loop ( while(1); ).
- Remove the second while(1) statement.
- Add an interrupt function.
Edit- Your main loop doesn't look like it is using interrupts. So, DO NOT enable them!
// CONFIGURATION BITS
// TODO: Add config bits
#include <xc.h>
#define f_timer 2000000
const unsigned short DIGITOS[] =
{ 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F };
void VerDisplay( int Frequency )
unsigned short U;
unsigned short D;
unsigned short C;
unsigned short UM;
UM = Frequency/1000;
C = (Frequency-UM*1000)/100;
D = (Frequency-UM*1000-C*100)/10;
U = (Frequency-UM*1000-C*100-D*10);
PORTB = DIGITOS[U];
LATAbits.LA0 = 1; // Strobe A0
__delay_ms(10);
LATAbits.LA0 = 0;
PORTB = DIGITOS[D];
LATAbits.LA1 = 1; // Strobe A1
__delay_ms(10);
LATAbits.LA1 = 0;
PORTB = DIGITOS[C];
LATAbits.LA2 = 1; // Strobe A2
__delay_ms(10);
LATAbits.LA2 = 0;
PORTB = DIGITOS[UM];
LATAbits.LA3 = 1; // Strobe A3
__delay_ms(10);
LATAbits.LA3 = 0;
void main ( void )
unsigned long signal_period, data1, data2;
int Frequency = 150;
OSCCON = 0b01110010; // IRCF2:IRCF0 = 8 MHz, SCS1:SCS0 = Internal Osc.
PORTA = 0;
TRISC = 0b11111111; // PortC direction bits
TRISB = 0b00000000; // PortB direction bits
TRISA = 0b00000000; // PortA direction bits
VerDisplay( Frequency ); // Initialize the display
// Setup CCP1 configuration
CCP1CON = 0x05;
CCPR1 = 0x00;
// Setup Timer1 configuration
PIR1.TMR1IF = 0;
T1CON = 0x80;
TMR1H = 0;
TMR1L = 0;
T1CON.TMR1ON = 1;
// Enable CCP1 interrupt
PIR1.CCP1IF = 0;
// PIE1.CCP1IE = 1;
// Main Loop
while( 1 )
void VerDisplay( Frequency ); // It looks like this should be part of initialization and be outside of the main loop
// You would only want to update the display when it changed???
// Plus, this should NOT be a definition. Remove the "void"
// I moved this to the beginning
while( !(PIR1.CCP1IF) );
PIR1.CCP1IF = 0;
data1 = CCPR1;
PIR1.CCP1IF = 0;
data2 = CCPR1;
if(data1 < data2)
signal_period = data2 - data1;
Frequency = ((float)f_timer / (float)signal_period);
// REMOVED the while(1). It was an infinite loop.
TMR1H = 0;
TMR1L = 0;
void __interrupt() isr(void)
// TODO: Handle CCP1 interrupts
if (PIE1bits.CCP1IE && PIR2bits.CCP1IF) {
PIR1bits.CCP1IF = 0; // clear CCP1 Interrupt Flag
// TODO: Process interrupt
