THD+N is a function of supply voltage and output power. For example, for a supply of 20V, the THD+N will be 1% or less if the output power is kept below 6W. If the signal is turned up to the point where the power exceeds 7W, then the THD+N will approach 10%. The curves are intended to show you how these three parameters are related.
