Author Topic: SSB transiter and receiver Tutorial/Explanation.  (Read 2553 times)
Offline firewalkerTopic starter
  • Country: gr
« on: January 24, 2014, 09:39:43 am »
Is there any analytic documentation for SSB transmitting and receiving? Not a mathematic analysis.
I can find scattered informations for SSB transceivers, bit no one explains what happen inside every build block of the transceiver.
Alexander.
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
Re: SSB transiter and receiver Tutorial/Explanation.
« Reply #1 on: January 24, 2014, 10:27:02 am »
(blatant plug follows)
Check out a few of these:
The basic modules needed in radio circuits - Parts 1 & 2
This is pretty much the simplest SSB transceiver you can get
A commercially made SSB transceiver
If you want to start more basic, it's worthwhile understanding direct conversion receivers and DSB transmitters before SSB receivers/transmitters.
A simple direct conversion receiver
A simple direct conversion DSB transceiver
Any questions? Ask them here.
NEW! Ham Radio Get Started: Your success in amateur radio. One of 8 ebooks available on amateur radio topics. Details at  https://books.vk3ye.com
  • Country: gr
« Reply #2 on: January 24, 2014, 10:29:43 am »
Thanks you! I will watch those asap.
Alexander.
