A lot of manufacturers these days stopped using doublers and just paralleled two power stages and their inductors and capacitors.
A 8 phase controller + doublers can be cheaper than a 14-16 phase controller and also some smaller controllers could be more flexible ... for example that 8 phase controller could be run in 6+2 or 6+1+1 modes and save another vrm controller
It may also be more advantageos for the manufacturer to stock on the 8 phase controller in huge volume and reuse it across a wide range of boards, while using a higher phase controller only on premium expensive models.
