Hello again guys,
Thanks for your response. But I am afraid you didn't fully get my point. Therefore let me rephrase my question. I have an a low frequency (up to several hundreds of kHz) analog circuit (a couple of op amps plus a bunch of passives) controlled by 8-bit micro. The design is powered by USB. All SMD, except connectors and buttons. My limitations are
- max PCB size => 100mm by 100mm
- four layers
- single sided load
How do you start? What do you do first?
Kind regards
Top layer is your component layer/routing layer
2nd layer is your ground layer. Be very careful not to break this up. Any though holes must have some copper between the holes. No routing.
3rd layer is your power layer. Also a very good idea to not break up this layer.
Bottom is your alternate routing layer.
Eagle CAD can do this for a small cost.
Kicad probably can do this too but I don't use it.
You really should have a local power regulator on the board even if your using USB. The length of the cable itself can be a problem when it comes to a sudden demand for power.
Step 1: Lay out components.
Step 2: Manually route board.
Step 3,4,5: Double check your design
Step 6: Export your gerber files and send to fabricator
