Thanks for the welcome, your welcome.
I've got lots of ideas in front of it, but I'm only starting small with a basic oscillation to run some blinky lights, I'm using a dc technique to generate the voltage, its similar to a voltage doubler, its a mini marx generator that is only going to increase the voltage a little, because I dont want to make it so large, its too many parts. If I do a 5 capacitor, it gets to about 150volts from my 30 volt beginners power supply.
Im using a version that has diodes instead of the spark gaps per capacitor, but I need 1 spark gap to time the oscillation.
I could make a larger one, but its just too big and clumsy, if I could do it lower voltage it would be so much easier. Maybe I should just buy it, I bet it doesnt cost much, but I thought maybe theres some crafty way of making one that ppl already know.
