I was planning to use a MAR6 in a simple GPS LNA, like a LNA4ALL.
I was just going to solder it to the end of the semi-rigid coax on my QFH antenna, with a 100n decoupling capacitor on the antenna side. Should I use a smaller value decoupling capacitor, any shunt capacitance, or series inductance on the output side?
If this won't work, then I just want to fool my GPS because it detects that the antenna as it is (without the MAR6) is OC and it won't function., so how could I do that? Resistor across/instead of the cap? I think it just wants to see some current, but not sure how it's detecting a proper antenna.
