It's difficult to say. The datasheet is not exactly complete and unambiguous. There are some possible indications that at 42 amps, the voltage is 48.2 volts, but at 0 amps, the voltage is 54 volts. That would explain what you're seeing. But the datasheet is... not clear. (Which in itself is a bad sign, since the only purpose for a datasheet is to be clear about how the thing behaves.)
It would be nice to know what voltage it puts out at some other load, being careful to manage the 2000 watts of power the specs suggest. It's hard to imagine that much power being needed for a charger of any kind, but... hey, what do I know?
To me, at least with the experiences of my own life, I might call it "the wrong power supply." That's because it's probably too big and too powerful and too, well, dangerous, to fit into any projects I could imagine doing. I don't know what you're up to!
