Hi all,
I'm trying to repair a synthesizer that features a slight variation of the "Barry Klein envelope generator" as shown in the attached schematic.
The problem as I understand it is the NOR SR latch which is not working at all for some reason..
When I trigger the rest of the envelope with a fast gate signal I get it to perform but I see no activity coming out of the SR latch with a gate signal applied.
I tried to replicate the circuit in a breadboard only to get the same behavior.
In my case the circuit is powered with a 12V so to get the 10V at the comparator input the 47k is 22k.
Also there is a 2.2k resistor in series with the potentiometers (which BTW are 1M not 5MΩ) to prevent possible unwanted lockups of the latch.
I'm puzzled to why this textbook circuit does not work at all..
I tried a tad bigger capacitors in the nor input to make the trigger pulse wider to no avail.
