Author Topic: Parallel or serial connection to a single power supply?  (Read 753 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: September 17, 2020, 03:32:48 pm »
I have tried to read, simulate and trawled YouTube thin but do not think I have found the right answer.
Below do you find 7 circuits, 3 current sources and 1 power supply with 1 positive and 1 neutral.
Some uses X amount of current, other Y amount and so on and one does use Voltage.
I imagine that one current source have to configured to drive those with same current usage.
How would you connect the letters? I have tried to simulate but gets different answers and the math do fast go sour for me.
I can't decide what has to be in parallel or series.
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Online Ian.M
Re: Parallel or serial connection to a single power supply?
« Reply #1 on: September 17, 2020, 03:40:50 pm »
You wouldn't.
As drawn, its incomplete as each load needs two terminals, as do the current sources, and if you are putting loads that require a constant current in series in real life you need to have some idea of their voltage drop so you can check if the combo will be in the voltage compliance range of your current source.
« Reply #2 on: September 17, 2020, 03:50:50 pm »
Yes I think I understand. You have the positive lead going trough a current source to a circuit and then back to zero. So in the end, every current source is connected to the positive, each current source is connected to one or more loads and each load is then connected to ground.
Hope it explains things?
« Last Edit: September 17, 2020, 03:55:46 pm by FriedMule »
Online Ian.M
« Reply #3 on: September 17, 2020, 04:40:50 pm »
Nope.  You need to put loads that require the same current in SERIES like a string of (dumb) LEDs.  If you put them in parallel, the current will be split depending on their operating voltage vs current characteristic, and either one will hog all the current or neither will get the correct current.
Otherwise the arrangement of current sources and loads is generally correct.
« Last Edit: September 17, 2020, 04:43:31 pm by Ian.M »
« Reply #4 on: September 17, 2020, 04:51:09 pm »
So
E and F in parallel on D
G and H in parallel on B
I on A
How would you connect D, B, A and J to the transformer?
Online Ian.M
« Reply #5 on: September 17, 2020, 04:56:47 pm »
Nope. E, F and D all in series, G, H and B all in series, then put all the branches in parallel between the supply and ground.
« Reply #6 on: September 17, 2020, 05:15:09 pm »
So like this? :-)
Online Ian.M
« Reply #7 on: September 17, 2020, 06:41:15 pm »
Looks OK
« Reply #8 on: September 17, 2020, 09:42:48 pm »
Fantastic, thank you a lot!!
