Author Topic: Finding peak values in Matlab  (Read 2021 times)
Offline KaramelTopic starter
  • Country: tr
« on: October 23, 2016, 08:35:19 am »
Hi everyone,
Nowadays, I am working on sound recognation project via matlab. I am currently able to realize some notes. All of them are good but, I, now, have a problem with matlab.
I should recognize frequencies of peak values in my array. (fourier output) So, I can find peaks in my array like that,
pks = findpeaks(abs(F));
[m,n] = size(pks);
for i=1:m
   fprintf('peak%i: %i\n',i, pks(i,1));
end
but it gives to me values of at max point. Not frequencies. (in frequency domain x axis describes frequencies and y axis describes magnetude of signal)
So, how can I get frequencies for all peak(local max values) values?
Best Regards,
Karamel
« Last Edit: October 23, 2016, 08:38:09 am by Karamel »
Offline ataradov
    • Personal site
Re: Finding peak values in Matlab
« Reply #1 on: October 23, 2016, 05:22:31 pm »
[pks, locs] = findpeaks(data)
locs will contain locations of the peaks.
Alex
  • Country: tr
« Reply #2 on: October 24, 2016, 02:29:07 pm »
Thanks for replying my question dear Atarov,
Actually, I had solved this problem when after asking but, I asked it and then, I went library, so I did not write solution.
[pks, locs] = findpeaks(abs(F))
[m,n] = size(pks);
In there, locs are local values, m and n are size of pks. If there is no signal. n = 1(n is always 1 because of pks is mx1 vector) and m = 0. If there is signal and is has some peak values, then, m has a different value that depends on peaks.
Matlab has a different coding and different approaching to solve problems. Okay, it looks like c programing but, certainly, it is different. I could, therefore, be asking stupid questions or etc. because of difference.
Thanks for all,
Karamel  ^-^
