Author Topic: Schematic for Stepper learning board (as in attached image)  (Read 363 times)
Offline amrat.ch@gmail.comTopic starter
  • Country: th
« on: August 10, 2024, 03:12:58 am »
Hi everyone,
Any ever see or have schematic or manual of this attached Stepper learning board ?
Thanks
Amrat
Offline MathWizard
Re: Schematic for Stepper learning board (as in attached image)
« Reply #1 on: August 11, 2024, 04:30:27 am »
Hi did you take the picture ? What would the zif socket/blue thing be for ?
Offline ledtester
« Reply #2 on: August 11, 2024, 04:46:55 am »
I think the ZIF socket is for an microcontroller. You've got a power inlet with a switch, bridge rectifier and bulk capacitor, a crystal with two small caps, and what looks like an RJ45 or 11 jack perhaps for a TTL serial port.
Take a pic with the top removed - that would give us a lot more info. I would expect to see something to drive the stepper coils - like transistors or motor driver chips.
« Last Edit: August 11, 2024, 04:52:24 am by ledtester »
Offline jpanhalt
« Reply #3 on: August 11, 2024, 09:48:28 am »
I agree, the ZIF is almost certainly for the MCU of one's choice.  The LEDs might be related to state, e.g., Example 2 here: http://ww1.microchip.com/downloads/en/AppNotes/00907a.pdf
A paper disk attached to an inexpensive stepper gauge (e.g., automotive) and solderless breadboard is what I used when playing with code for them.  Adafruit has an inexpensive breakout board, schematic, and code for learning: https://www.adafruit.com/product/2448
