Author Topic: Automotive Mosfet Driver  (Read 378 times)
Offline NotDaveTopic starter
« on: August 09, 2024, 04:42:14 pm »
I am building a DIY PDM for an automotive project, I have the following circuit for the outputs, there are 12 of them with the MAIN12V and GND-PWR all connected together. The issue that I am having is the output on indicators for each channel are slightly illuminated all the time and if I PWM an inductive load they flash on all channels with the flyback.
Do you have any suggestions on how to better design the output status LED's or better protect the outputs from flyback? I am assuming there is diode leakage or something?
Online TimNJ
Re: Automotive Mosfet Driver
« Reply #1 on: August 09, 2024, 05:16:19 pm »
Is the MOSFET really turning off? What is the gate source voltage? Check if it's really pulling down the gate-source completely to 0V. Do you really have the two GND pins disconnected?
Schottky leakage is pretty high, yes, but maybe only 10uA @ 25C here, which is probably not enough to turn on the LED noticeably. I can't remember, off hand, how efficient the high efficiency greens are..
Just remove the top diode and check.
« Reply #2 on: August 09, 2024, 06:03:56 pm »
All the grounds are common through the car, the GND-PWR is just a reference to the large copper pour for the lug to connect grounds.
The mosfet is controlled with the high side drive since it is a N channel, here is a table from the datasheet.
I will scope the mosfet gate pin and see if it is going to 0V or not
Offline Le_Bassiste
« Reply #3 on: August 11, 2024, 08:35:37 am »
...I am assuming there is diode leakage or something?
it's the supply current of your gate driver on PIN6 (and then coming out of PIN2) that's flowing through the LED.
An assertion ending with a question mark is a brain fart.
Offline PGPG
« Reply #4 on: August 11, 2024, 02:58:50 pm »
Add resistor paralel to LED.
The following users thanked this post: boB
« Reply #5 on: August 11, 2024, 05:19:41 pm »
Thank you!
