Author Topic: Maximum transient current through a transistor?  (Read 962 times)
Offline dsegel
« on: August 18, 2017, 05:14:10 pm »
I have an application where I want to switch a path through a transistor that will be +/-20V and may go up to 2A. The current will only be flowing for about 100ms, with at least 1 second in between. I'm currently planning on using a ULQ2003A transistor array because I need 6 of them to control 6 devices independently.
My question is, how do I know if this will work, or if I'm going to blow up the transistors? The datasheet for the ULQ2003A is here: http://www.mouser.com/ds/2/389/ulq2001-957368.pdf
If necessary I could lower the voltage a bit.
Offline Zero999
  • 0999
Re: Maximum transient current through a transistor?
« Reply #1 on: August 18, 2017, 05:51:21 pm »
The data sheet specifies a peak current of 600mA.
Another issue you may have is that the Hfe of the transistors might not be high enough to give a low enough on voltage. The transistor might operate in its linear region acting like a current sink, dropping most of the voltage, leaving very little for the load.
The following users thanked this post: dsegel
Offline BigBoss
« Reply #2 on: August 18, 2017, 06:05:15 pm »
If you application is purely to switch a signal during 100ms, I recommend you to use Switching MOS Transistors.They have more current carrying capability and higher dissipation capacity on them.
http://www.onsemi.com/PowerSolutions/product.do?id=FDMQ8403
It's got 4 channels.
Offline dsegel
« Reply #3 on: August 18, 2017, 06:19:21 pm »
Yeah, i just read up on Hfe and realized it might be a problem.
I saw the 600mA spec, but didn't know if that applied to transient events.
Offline dsegel
« Reply #4 on: August 18, 2017, 06:21:20 pm »
Thanks, I'll check it out.
Offline danadak
« Reply #5 on: August 21, 2017, 12:14:31 am »
Google "octal power driver", a number of alternatives. Darlingtons suck because they
have such high Vcesat.
Regards, Dana.
