Yep, better.
Hard to say why you needed such a lot of VAS capacitance but the main thing is that it works, i guess. Usually it is under 100 pF or so, but never mind. Perhaps you will want to check the high frequency roll off point if the cap is way larger.
One comment regarding the feedback, which should increase the stability margin perceptibly: the impedance level can easily be lower, since you are not short of driving ability in the output stage. Lowering to 1/10th would be beneficial against thermal noise in the resistors. Otherwise it should work as it is, too.
