Hello
I'm trying to build a 5V to 12V boost converter using the MC34063ABN.
This is just something I build to understand boost converters better, so I have completely ignored efficiency, and used parts that I had on hand.
I previously had problems with the MC34063ABN, so this time I kept very close to the Data-sheet.
The problem that I had, was that as soon as I used a smaller load, the voltage of the output rose above the 12,6V I wanted.
As I said I used what I had lying around for the components, so that was the place where I started looking for the problem.
1. The diode I used is not a Schottky diode and has a large(1.1V) voltage drop. But from my understanding, if the Diode was the problem the output voltage would be to low, and not to high. So I don't think the diode is the problem.
2. The inductor is a selfe-wound coil with an air-core that I had lying around. The Inductance (measured with a cheap component tester) is twice what I need as minimum inductance, but I don't know how much the inductance will drop with the current. But again a lower inductance should cause a lower and not a higher output voltage. The high resistance of the coil(0.7Ohm) is bad, but if it's a problem it should result in lower and not higher output voltage.(at least to my understanding)
3.The timing capacitor I used consists of two ceramic capacitors(470pF+100pF) and together slightly lower then the 617pF I calculated using the formulas in the data-sheet.(f min 50kHz)
I don't think it causes the problem, but I'm confused by the readings from the frequency I measured at the timing capacitor and at the switch directly.
The frequency on the timing capacitor was stable 58.8kHz, but the frequency at the switch varied from 165kHz to 130kHz depending on the load.(Higher load, lower frequency)
Which is higher than the frequency the chip is rated for.
4.The resistor divider I used was also made from resistors I had lying around, so the output voltage should be 12.6V instead of 12V. In addition, the resistors are +-5%.
The second resistor over which the 1.25V voltage drop for the reference occurs, is exactly as big as the one in the data-sheet. So the current should also be the same.
Now after all my digging, I think the problem is that the boost converter needs a higher minimum current than occurs with some of the test setups.
The boost converter works fine with a 1kOhm and with a 470Ohm load, but fails to regulate the voltage down to 12.6V with a load larger than 10kOhm, and reaches voltages of 20V and higher.(up to 28.6V with no load)
So now my questions.
1.Is my reasoning correct and the problem is the low current? Or have I completely overlooked something else and the problem is something else?
2.What's up with the frequencies I've measured? They don't make any sense to me. So I would be grateful if someone could explain them to me.
3.If the low load current is the problem. How do I find out what the required load current is, and does it make sense to design the resistor divider in a way that the voltage converter always regulates the voltage properly, or should I use a separate resistor for that.
TL;DR
A boost converter I build using the MC34063ABN doesn't regulate the voltage with a small load attached to it. Why?(probably a to low load current) and how do I prevent that?
