Hello,
I am using an USB OTG (on-the-go) capable MCU.
I would like to know if I could use only one connector to read an USB key and also connect to PC which send commands (not at the same time !).
In the first case, the MCU would be host and in the second it would be device.
As far I understand, I need the 5th pin 'ID' which is only available on mini and micro usb connectors, but I cannot connect a stick on these.
Am I forced to add another connector ?
Thanks for your advice.
