Author Topic: Meaning of O-NEG marking on an electrolytic  (Read 471 times)
Offline phonedawgzTopic starter
« on: February 22, 2020, 09:51:46 pm »
Doe the O-NEG marking on this electrolytic indicate the lead on the bottom with the engraving is the cathode?  If not what does it indicate?
Offline Gyro
Re: Meaning of O-NEG marking on an electrolytic
« Reply #1 on: February 22, 2020, 10:21:36 pm »
Yes, it indicates the textured surface on the rivet on the bottom. It seems rather redundant in this case as the sleeve has the white negative band down the side too (Maybe they use it themselves to align the sleeve  :)).
« Last Edit: February 22, 2020, 10:23:23 pm by Gyro »
Best Regards, Chris
« Reply #2 on: February 22, 2020, 10:51:22 pm »
Thank you
