Each time I look on this circuit I see more mistakes, even potentially lethal ones. If I were you, I would not try to build it.
Or it's unfinished circuit, who knows.
Optocoupler, which is driving MOSFETs, does not perform its function - isolation. Even if you supply right-side (with phototransistor) with separate isolated power supply, it still does not include 'turn-off' function for switches, only that 10k pull-down resistor can actually close them, which is bad for transistors.
Returning to your question, if you dare to build it, do not connect anything earthed to it.
