I recently installed leds in the dashboard of my car and while they dim, they don't dim much before they simply drop out. The factory dimmer works by varying the output voltage to the bulbs from 9-12vdc, which explains why the bulbs drop out without significantly dimming. So, I'd like to build a circuit to go inline with the factory dimmer to provide significant dimming to the leds.
It seems the most common method of dimming a led is to use pwm, so I googled for pwm circuits. There's certainly a bunch of circuit designs out there, but they seem to be controlled by varying resistance from a pot, and not from a variable voltage source. I need to control the pwm using my 9-12vdc voltage source. I do have access to 14vdc power from the fuse panel that I can use if needed.
I'd like to be able to vary the duty cycle as much as possible, but an old scratchy pot that only has a 3 volt range isn't going to give a lot of fine-grain control. And no, changing the pot or how it's wired up isn't an option. My only available spot to tie in without affecting other circuits is between the pot and the dash.
Any suggestions on how to build the circuit?
