Author Topic: Measurement aborted HP 54503A  (Read 625 times)
Offline xaaanderTopic starter
« on: January 31, 2023, 04:45:56 pm »
Hello. I recently changed NVRAM.
When I want to use ''blue functions'', selecting  Frequency for example, I choise  canal 1 with bnc from AC rear signal, I got this message:
Function is off.
Measurement aborted.
It's the same with all function.
How to turn on function ?
Thanks you.
Online Stray Electron
Re: Measurement aborted HP 54503A
« Reply #1 on: January 31, 2023, 09:26:09 pm »
I have a HP 54510A and a couple of newer 545** models and AFIK there is no way to turn off those functions.  I think that your message is due to some kind of malfunction and the software detecting that and is causing the measurement to abort.
« Reply #2 on: February 01, 2023, 09:49:58 am »
Ok. Thanks you. I 'll try to calibrage again
« Reply #3 on: February 01, 2023, 05:52:25 pm »
  Have you checked that the rear output is actually putting out a signal?
« Reply #4 on: February 02, 2023, 09:56:28 pm »
AC rear signal is ok, but as you mean, DC signal isn't. Do you know what IC is using to create DC signal?
Small connector from BNC to board is ok.
« Reply #5 on: February 03, 2023, 01:17:39 am »
  No, I've never been inside of any of the HP 54xxx scopes so I have no idea. You might search through some of the old HP Journal articles and see if they have any articles about the 54xxx scopes. Those usually have a good technical description.  The only "repair manual" that I've even seen for the 54xxx scopes just say to replace the entire circuit board and there is no technical information.
