MODERATOR: Please move this thread over to the "Repair" section, the topic fits there a lot better!
Hi ziplock,
Sorry for the delay, I did not read this forum for a while!
That is a bummer that the dual FET is blown! Looks like whatever took out that Q001/101 FET, used just as a protection diode, that also damaged the dual FET!
When you say that uPA61A is expensive, just how expensive is that ? You should compare its price to the replacement value of a dual channel 20MHz analogue scope!
That aside, I did check a number of present day dual J-FETs. The only thing that those are not a good match for a uP61A. The uP61A has an Idss current about 2mA - 6mA, the present day dual FETs are in the 20mA to 30mA range! (They are also all SM devices!)
Idss is the current through a J-FET when the Vgs voltage is zero. That is a key parameter when replacing a J-FET. (See the J-FET on wikipedia: <https://en.wikipedia.org/wiki/JFET#/media/File:JFET_n-channel_en.svg>)
There are number of "older", single J-FETs available with such low range of Idss, through-hole, like the BF244A, BF245A, J113, 2N3822.
I would get a handful (10 - 20) J113 FETs (U$3.13 for 10 at DigiKey) and would select them for Idss. You would want to match two of them as close as possible. Connect the gate to the source, add 10VDC to the source and drain, and measure the current at the source. Pick two FETs where the current is the closest to each other and to the 2mA value!
The other beauty of the J113 is that it is a symmetrical device, drain and source are interchangeable, so when you glue them together at their flat faces you have a choice of pinouts! (use a drop of superglue)
But do measure the Idss as you would use them in the circuit!
Do not worry that you have no substrate (pins 4 and 8 on the uP61A) to tie to!
EDIT: Make that J-FET rather the BF244A or BF245A, the J113 is a switching FET! I will investigate that J113 further!
I will also plug that input circuit in to the simulator to see if there are any other issues!
I also do have an 5702 scope, for about 30 years now, running just fine.
Regards, Peter
