Thank You Ian.M
I really appreciate your help. Sorry I am not used to work with negative voltages....
Well I have a -15V supply which powers the current mirror for the constant negative current and a +3.6V where the (-15V) negative voltage is produced from via a boost converter.
So I was thinking connecting Vcc of the OPAMP to the 3.6V and VEE to -15V.
Does this shift the "ground level" inside the OPAMP at -9V?
You wrote: "OPAMP buffers to get an arbitrarily high input impedance ". Do I need to put also a buffer before the differential? are the +/- IN high impedance of an OPAMP itself not enough?
Simply sensing the voltage waveform on the load side of the capacitor is sufficient to detect most fault conditions. If its flat 0V, the signal source or grounding switch has failed. If its a triangularish waveform with limited amplitude, its operating normally. If its a 15V pk-pk squarewave, the 1K load is open circuit.
Yes that would perfect .. but how to do it?? I actually have voltage drops on the load for 600us then 2400us load is shorted to ground.
