Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Measuring Current in Inductor Circuit
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Measuring Current in Inductor Circuit (Read 1700 times)
eev_carl
Regular Contributor
Country:
on:
August 21, 2017, 02:16:06 pm »
I'm measuring the current in an inductor circuit, but it doesn't match my calculated values. I was wondering if someone could explain the discrepancy to me. The circuit is 10 x 1uH inductors in series with an AC voltage source of 1.77V at 25KHz. I calculated the reactance to be 1.57 ohms and the current to be 1.13 A (1.77 / 1.57). However, when I measure the current with a DMM, I get 14.2uA.
This is a link to the inductors that I'm using:
http://www.mouser.com/ds/2/390/RCH-654-523455.pdf.
Thanks,
Carl
Last Edit: August 21, 2017, 02:19:04 pm by eev_carl
Logged
Benta
Super Contributor
Country:
Re: Measuring Current in Inductor Circuit
Reply #1 on:
August 21, 2017, 02:48:57 pm »
Is your DMM able to measure anything at 25 kHz? BTW, I get 1.57 as well.
Logged
eev_carl
Regular Contributor
Country:
Reply #2 on:
August 21, 2017, 03:09:28 pm »
Thanks for replying. In the DMM manual, it lists a frequency range of 50 to 400Hz. My DMM is a Klein Tools MM700.
-Carl
Logged
Benta
Super Contributor
Country:
Reply #3 on:
August 21, 2017, 04:40:16 pm »
A long way up to 25 kHz, then.
Logged
Zero999
Super Contributor
Country:
0999
Reply #4 on:
August 21, 2017, 09:50:52 pm »
Use an oscilloscope and sense resistor or current transformer. Note that the oscilloscope's chassis will be connected to mains earth and if your 25kHz signal source is to, the sense resistor idea may be a no goer: use a current transformer instead.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
