Author Topic: IR Spot sensor/alarm.  (Read 475 times)
Offline paulcaTopic starter
« on: April 07, 2023, 09:22:43 pm »
Off the tip of the hat...
A simple, cheap IR camera you hang over your bench (or where ever).  It, much like an IR fire sensor but a little more touchy, will look for heat spots.  If a heat spot gets above a certain temp, it raises an alarm.
How cheap can you make it and how effective would it be?
It's ... something that might light up a few seconds before you smell the magic smoke about to release... it might save you from what I did last week and ... touch the MCU to see how hot was while shorted and consuming about 20W.
A 60*C orange light.   80*C Falshing orange.  100*C auidble  alarm say.  All adjustable.
Note.  The MCU was NOT 60*C, or 80*C... it's was Awwwwww fuc....!!!  hot and 3 days heeling.
Offline jpanhalt
Re: IR Spot sensor/alarm.
« Reply #1 on: April 07, 2023, 09:37:59 pm »
Internet:
(CMOS) sensors can exhibit near-infrared (IR) sensitivity from 700 nm to approximately 1,100 nm
In terms of temperature, 1100 nm is a lot hotter than I want my MCU to be running at.  :) (See:attachment)
Offline JustMeHere
« Reply #2 on: April 08, 2023, 12:38:15 am »
Use the temperature sensor in the MCU.
Offline barshatriplee
  • Country: bd
« Reply #3 on: April 08, 2023, 12:15:22 pm »
I think adding an LM35 or DS18B20 to your circuit will be more convenient.
