What make of plasma cutter is that, there could be very high voltages on some of those pins if that is the torch socket. My Lincoln plasma cutter has an open circuit voltage of 300 volts and a switchable 30 or 50 amps, so although the transformer is wound for a drooping voltage such that once the arc is struck and stable it is only around 24 volts it would still be lethal to come into contact with the circuit also the HF gets every where when the trigger is first pulled and before the arc is established and that voltage is in the thousands, so you will most likely need inductance in the circuit to stop the HF from travelling into you circuit.
