Author Topic: SOT-23-8 for Eagle  (Read 10021 times)
Offline ARGLaserTopic starter
SOT-23-8 for Eagle
« on: December 06, 2012, 04:36:43 am »
Hey everyone,
I'm using Eagle to make a PCB and I have an ADC in a SOT-23-8 package. I can't find anything with the included eagle librarys, and I can't find anything from searching on Google. Can someone point me to a library with a SOT-23-8 device so I can use it in my circuit?
Thanks
-ARG
Offline ju1ce
Re: SOT-23-8 for Eagle
« Reply #1 on: December 06, 2012, 10:35:18 am »
You might as well make the footprint yourself. Sooner or later you need to make another one and it doesn't take very long if you already know how to do it.
Offline LEECH666
« Reply #2 on: December 06, 2012, 10:53:36 am »
Quick google search revealed the following:
maxim.lbr (Device MAX4337.DEV / SOT23-8L.PAC)
Result was in German tho.
Hope that helps.
Cheers,
Florian
« Reply #3 on: December 06, 2012, 06:04:27 pm »
Ideally I would like to be able to do this but I haven't been able to find a good tutorial on how to do it.
Hope that helps.
I found that German result as well, but there was no download link so far as I could see.
Offline Jon Chandler
    • Throw Away PIC
« Reply #4 on: December 06, 2012, 08:48:34 pm »
Check out my tutorials linked here.
Creating parts is actually pretty simple once you have the process down - way faster than searching for a footprint.
One hint:  Be sure to use whatever units (imperial or metric) the part was designed in when creating footprints.  Rounding errors add up fast!  The attachment shows pads that should be on the same pitch; notice how quickly the error adds up when using converted measurements.
Offline IceKiller
« Reply #5 on: December 06, 2012, 08:48:55 pm »
Offline hlavac
  • Country: cz
« Reply #6 on: December 06, 2012, 08:54:21 pm »
It is really easy to make footprints in Eagle once you find out what all the different layers are for.
You will want to make your own anyway, many of the supplied footprints don't even pass the DRC because of solder mask overlapping pads etc.
Good enough is the enemy of the best.
« Reply #7 on: December 06, 2012, 10:13:39 pm »
try this one
http://domos2010.googlecode.com/svn-history/r8/trunk/maxim.lbr
probably the right one..
That's it, thanks!
I'll check that out in the future, I am likely to need this again :)
