It seems that most or all dell computers use a 5 pin custom connector for fans, but it's easy to wire a 4 pin PWM fan to the Dell connector.
I'm looking to replace all the fans in a Dell with PWM fans and a PWM controller. This controller sends back one 4 pin PWM to the motherboard for control.
The Dell motherboard has two fan connectors i would need to populate to not get a fan error. Is there any reason it wouldn't work if I cut off the 4 pin fan connector and solder the two wires for PWM control to both the motherboard fan connectors?
I wanted to check and see if there was any reason this wouldn't work before i buy anything and cut off any fan connector.
Thank you all!
