With us not knowing how exactly the testing rig looks like, we may only guess.
My guess would be: there is no testing rig at all, not one suitable for the signals considered, and probes are just connected to traces. Which means you built yourself some antennas from wire loops. Scope displays whatever those antennas pick up, likely bandwidth limited, affected by transmission line effects and various kinds of noise.
If you wished to repeat AlphaPhoenix’s demos
(1)(2)(3) on signal propagation in wires, note his traces are very long to avoid get around
how fast causality propagates, he spent much more time than it’s apparent from the videos on making it all work, has some decent experience, and still is on the tip of what he can do.
Unfortunately my experience in this area ends with knowing what doesn’t work. So beyond telling you, that the setup seems not suitable for the task and you just see garbage, I can’t give much advice. To see, what I meant by “testing rig,” you may see the example from w2aew.
(4) But even best practices will not let you ignore physics: the signal propagates at
foot per nanosecond speeds.
(1) “Watch electricity hit a fork in the road at half a billion frames per second”:
(2) “I bought 1000 meters of wire to settle a physics debate”:
(3) “Why does WATER change the speed of electricity?”:
(4) “#111: How to make a high performance oscilloscope probe socket”:
