I would like to ask a question if someone experienced could clarify.
Assume two setups:
1 - DC Load, 10 cm long 10 sq. mm. thick wires with remote sensing attached
2 - DC Load, 100 cm long 5 sq. mm. thick wires with remote sensing attached
I'm pretty sure that voltage will read properly, but what about current? Say 30 Amps with every setup?
Thanks in advance and sorry if it is a dumb question.
