Author Topic: Solved Datron 4000A Fail 5 over 190 volts  (Read 134 times)
Offline Johnny10Topic starter
« on: November 20, 2024, 04:49:09 pm »
I'm having a problem with my Datron 4000A.
On High Voltage output anytime I try to go past 199 volts I get a Fail 5. OOPS
Now I get to 100 V and I get Fail 5.
When I run self test result is PASS.
Any thoughts?
I don't think I kept good notes when I worked on these Datron 4000s back in 2017.
Seems my original thought that it was a relay problem was correct?
After trying different methods of getting to 500-600 volts both positive and negative.
I found that after sneaking up to that number without turning off the output, the relays were worked and it allowed me to continue without a FAIL.
Several attempts at this and so far I can go to the higher voltages without a FAIL 5.
It has been sitting for three four years now.
« Last Edit: November 20, 2024, 08:06:51 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
