Hello everyone!
I failed miserably with the famous search engines (Google, Yahoo, Bing, etc), please help me to mention these components.
I don't expect you to have multiple datasheets and be ready to scan them.
And besides, I have a bunch of datasheets to share in case there's something you're missing.
But I couldn't find anything from some datasheets, so they keep looking for the datasheets they recognize in the following list:
Adjustable Inductor with Magnetic Core, High Frequency Inductance Intermediate Coil "Sperferes 16 kHz, VOGT 524 01 015 00".
TV-66 = Transistor for Audio AmplifierOR-101 = DIAC without data sheet, I need to know if it is equivalent to DB-3 or not?
SKR130/S and SKN130/S = Power Rectifier Semikron, if a datasheet shows only maximum voltage number, and I didn't find any letter "S" of maximum voltage or I don't know if "S" would be 400V or 600V, but I can't know which one.
T51A065005AQ (date 1970s) = Power Thyristor
Telefunken TLDR 5200 = LED DiodeTelefunken TAPV 5051 = Cylinder Red/Green LEDs Module
Telefunken TDBR 5150 = Alphanumeric LED Display
Siemens FZJ131 = Quad D Flip-Flops DTL
Telefunken (Temic) U3079M = Microcomputer Controlled Display Driver with 34 Outputs
Telefunken (Temic) U3081M = Microcomputer Controlled Display Driver with 15 Outputs
Telefunken (Temic) U3082M = Microcomputer Controlled Display Driver with 19 Outputs
Telefunken (Temic) U3084M = Microcomputer Controlled Display Driver with 19 Outputs
Telefunken (Temic) U3085M = Microcomputer Controlled Display Driver with 19 Outputs
Telefunken (Temic) U3088M = Microcomputer Controlled Display Driver with 8 Outputs
Telefunken (Temic) U3090M = ?
Telefunken (Temic) U3091M = ?
Telefunken (Temic) U2000B = Timer for Electronic Flash
Telefunken (Temic) U2024B = Programmable Zero Crossing Switch
Telefunken (Temic) U2800B = Room-Thermostat Zero Voltage Switch
Telefunken (Temic) U6048B = ?
Telefunken (Temic) U639B = ?
Telefunken (Temic) U6039B = ?
Telefunken (Temic) U212B = Analog Processor for Speed and Torque Control of Electric Machine
Telefunken (Temic) U2351B = PWM Speed Control for Permanent Excited Motor
Telefunken (Temic) U2401B = Low Cost Rechargeable Lithium Ion Battery Charger
Telefunken (Temic) U2501B = IR-FB Receiver Amplifier 20-50 kHz
Telefunken (Temic) U2507B = IR-FB Receiver Amplifier 20-50 kHz
Telefunken (Temic) U351M (U350M) = 10MHz FET Signal Switch
Telefunken (Temic) U450B1 = ?
Telefunken (Temic) U450B2 = ?
Telefunken (Temic) U3042M = Triple 10-bit Digital-to-Analog Converter - Dynamic Range 60dB
Telefunken (Temic) U222B = Car Engine Ignition
Telefunken (Temic) U2028B = Hall Effect - Magnetic Field Sensor - Electronic Car Engine Ignition
Telefunken (Temic) U2129B = Car Engine Ignition
Intel U5000M = ABUS Interface Module for Automotive Bus
Temic U5001M = ABUS Interface Module for Automotive Bus
Thanks!
