Author Topic: USB Ground referencing  (Read 2378 times)
Offline codycodeTopic starter
« on: April 17, 2016, 06:09:03 pm »
So I decided that I wanted to make a powered USB cable.
The layout goes something like this; Wallwart USB charger -> VCC, GND -> Female USB <- D+,D-,GND <- Laptop
So my laptop's ground will be referenced to the charger's ground, or in other words I'm referencing the grounds of 2 USB busses together.
I just wanted to make sure that this would not cause some sort of ground loop, or power contention. So does this should potentially harmful, or should this work just fine?
Offline stmdude
Re: USB Ground referencing
« Reply #1 on: April 17, 2016, 06:40:48 pm »
I can't figure out how you want to wire this thing up. Maybe a picture would help us understand?
If it helps, the "ground" on USB Wall chargers is floating, so it'll adapt to whatever ground-potential your laptop has.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: April 17, 2016, 09:49:18 pm »
This is one reason why PSUs have isolated outputs.
If your USB charger does not have isolation... send it back  :scared: :scared: :scared:
Seven Transistor Labs, LLC
Offline Michaelbradford
« Reply #3 on: April 18, 2016, 12:18:42 am »
Check out bigclive.com on you tube he does a lot of USB stuff msg him he quite good
