I used to build large arrays of x-ray detectors, and we used linear power supplies for noise reasons.
The younger engineers wanted to use switchers, and I replied that it was possible but that they had to budget engineering time to ensure noise performance, since the switching frequencies were in a range that our analog electronics was susceptible to.
Hand-waving doesn't count: the switching noise can be radiated, imposed on the DC outputs, and conducted back to the AC mains.
There are engineering solutions for all of these problems.
Linear power supplies have lower efficiency and generate more heat, but can be more quiet if properly built.
