Author Topic: metal ring on joint PCB  (Read 499 times)
Offline zennon
« on: July 08, 2018, 05:00:25 pm »
New to soldering, tried to desolder a mouse switch on a PCB. I thought i did a good job, but it's not working with the replacement. I did change it with a different brand of switch so not sure if that's the reason
OR
while desoldering, i removed also a metal ring from the joint in the back of the PCB? Is that an issue? That joint, the solder doesn't stay down but form like a bulb. If that the problem, which is most likely, is there a way to replace that metal ring? I thought most contact and circuits are on the front side of a PCB?
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: metal ring on joint PCB
« Reply #1 on: July 08, 2018, 05:05:45 pm »
You just killed the solder pad. The metal ring is called a plated through hole, and is used to conduct electricity between layers of the board as well as to secure large component connections.
Offline JS
  • Country: ar
« Reply #2 on: July 08, 2018, 05:46:06 pm »
Don't worry too much, if there is connection to that place from both sides of the pcb solder a very thin wire from the switch side crossing to the other side, put the switch in place, solder the switch and the thin wire to whatever is left on this bottom side.
JS
If I don't know how it works, I prefer not to turn it on.
Offline zennon
« Reply #3 on: July 08, 2018, 06:00:13 pm »
Here is a pic. Somehow the eyelets of BOTH middle joints came off when using the pump. The other ones are good, so don't know if i did something wrong or they weren't firmly attached to the board initially. How do you repair those eyelets? They are like 3mm? I have a different board that i could pull some out probably but is it possible and if so how to remove?
Offline JS
  • Country: ar
« Reply #4 on: July 08, 2018, 06:02:04 pm »
Overheating lift pads, not rare to happen, as I said don't worry too much and ensure conections with bodge wires
JS
