Author Topic: Metallized Polyester Film Capacitors  (Read 2092 times)
Offline SG-1
« on: February 19, 2011, 12:07:27 am »
The capacitor has a DC rating, but neither end is marked +/-   ???
http://www.vishay.com/docs/42091/v430p.pdf
Works either way ??   :-\
A .47micro-F is being used in parallel with a 400V 40A diode in a 125VDC circuit.
Advice is a dangerous gift, even from the wise to the wise.
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: Metallized Polyester Film Capacitors
« Reply #1 on: February 19, 2011, 12:44:08 am »
These caps are non-polarised, so can be used any way round.
Only caps that use 'special' dielectrics to achieve high capacitances are polarity sensitive - e.g. electrolytic, tantalum, aluminium polymer.
Day Job: Mostly LEDs
Offline SG-1
« Reply #2 on: February 19, 2011, 01:55:29 am »
Well now, that just takes all the potential for excitement out of this circuit !  ;D
Thank you very much.
Offline Zero999
  • 0999
« Reply #3 on: February 19, 2011, 09:50:38 am »
Yes they're non-polarised and note how much larger they are than electrolytics of the same value and voltage rating.
