Author Topic: Need simple transformer - but nobody sells it?  (Read 1356 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
« on: January 24, 2021, 01:07:32 am »
Hi I have searched about every component shop I can remember but have not found what I need.
240VAC to -8VDC — 0 — +8VDC min 3VA6 it can maybe be 9VDC, but it will only add to the heat and I hope to avoid heat if possible.
How do I get such a transformer?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Online langwadt
Re: Need simple transformer - but nobody sells it?
« Reply #1 on: January 24, 2021, 01:18:29 am »
a transformer doesn't output DC, you need a powersupply
Offline ledtester
« Reply #2 on: January 24, 2021, 02:30:55 am »
Have a look at this page:
https://www.hammfg.com/electronics/transformers/power/266
Maybe a 266G14 will work for you if you use a low drop-out linear regulator.
Or a 266G16.
« Reply #3 on: January 24, 2021, 02:45:56 am »
Yes the VDC was a stupid mistake, I meant VAC. :-)
Thanks for the link, are those of okay-ish quality, meaning above eBay? :-)
Offline ledtester
« Reply #4 on: January 24, 2021, 02:52:30 am »
https://www.hammfg.com/about
« Reply #5 on: January 24, 2021, 02:58:59 am »
Thanks for that link also, I am in no way surprised that they write highly about themselves, but is it true? :-)
Offline dcarr
« Reply #6 on: January 24, 2021, 03:09:34 am »
Hammond is good.
Offline james_s
« Reply #7 on: January 24, 2021, 04:12:19 am »
Hammond is top notch stuff, at least it was. I've used their project boxes before and liked them.
This should be very easy, there are lots of transformers in the right ballpark but maybe you could explain a bit more about your project? What is the ultimate voltage you wish to get out of it? Keep in mine the voltage out of the transformer is often considerably higher at light load than when fully loaded, and also when you rectify and filter AC the resulting DC voltage will be significantly higher than the AC out of the transformer.
Offline CatalinaWOW
« Reply #8 on: January 24, 2021, 04:33:49 am »
Before the onset of SMPS transformers were much more widely available than they are now, but even then there were relatively limited numbers of standard parts.  When you go to parts shops you are finding NOS of once standard transformers (120 or 240 V mains to either 6.3 V AC  or 12 VAC for filament power in tubes, mains to 170-300 VAC for plate supplies, later came mains to mid range ac voltages for transistor based amplifiers and radios, along with a few impedance matching types 4, 8 or 16 ohm outputs) and surplus production of transformers that were custom ordered by builders of various things.
When you want to specify input, output and capacity you are really narrowing the field.  Your choices are to wind your own, order a custom job (very pricey) or make do with something you find.  Or maybe get lucky.
Offline james_s
« Reply #9 on: January 24, 2021, 04:41:10 am »
I used an iron transformer in a product a few years ago, I selected a nice tidy potted toroidal part. They had them in a range of voltages, 6.3, 8V, 9V, something like that. Custom values available if you want a bunch of them but even in single quantities there was more than 6.3 and 12.6V, most center tapped.
Offline WattsThat
« Reply #10 on: January 24, 2021, 04:44:04 am »
Signal Split/Tran has that exact configuration for voltage but you’ll need to go with 6VA. $10.50 Qty 1 from  DigiKey.
https://www.digikey.com/en/products/detail/signal-transformer/DST-4-16/953071
Offline WattsThat
« Reply #11 on: January 24, 2021, 04:54:48 am »
Another one with chassis mount and flying leads, 5VA.
https://www.digikey.com/en/products/detail/triad-magnetics/VPL16-300/4835125
Offline Jwillis
« Reply #12 on: January 24, 2021, 09:39:55 am »
Here's another transformer manufacturer https://www.antekinc.com/transformers/
Offline drussell
  • Hardcore Geek
« Reply #13 on: January 24, 2021, 03:14:57 pm »
That should be an easy requirement to fill, there are many choices readily available.
I even happen to have a tube of Tamura 3FD-416  :)
Digikey lists at least 17 different models that are 8 or 9 volt dual secondaries, 230 volt capable primary in the 3.2-6 VA range, and that's just a quick search in the standard through-hole PCB mount, mostly laminated style parts.  There will also be flying-lead torroids and "chassis-mount" parts that meet your required specifications.
examples here: Digikey - Power Transformers - Filtered
