Author Topic: micro-usb on radon detector  (Read 35519 times)
Offline cb831a
Re: micro-usb on radon detector
« Reply #75 on: January 20, 2024, 11:48:12 pm »
its normal. it has to do with temperature and ground hydrological pressure and other things. they are not consistent I noticed quite a large variation.
Not sure what you are referring to - can you elaborate ?
Offline djnebs
« Reply #76 on: January 21, 2024, 02:19:52 am »
What chip is the usbttl? When you scoped it, did you leave a trigger on it for the whole 24hours? The only thing that comes to mind is that it's sending something very infrequently (like every 24hrs). Can't imagine why... especially in the case where you didn't plugin the usb data pins.
Quite strange.
Offline cb831a
« Reply #77 on: January 21, 2024, 11:09:58 am »
https://auseparts.com.au/FT232RL-3.3V-5.5V-FTDI-USB-to-TTL-Serial-Adapter-Module
Quite strange.
No, as I had nothing to trigger on - I did free-run at .2s/div at humspeed and at 4800baud speed - after that I scanned through all the speeds.
Why would a once/24h trigger affect the whole day of operation. I would expect triggers within each hour ?!
Offline coppercone2
« Reply #78 on: January 21, 2024, 08:53:15 pm »
radon levels might average in a year. seasonal dependence too
Offline cb831a
« Reply #79 on: January 28, 2024, 10:12:40 pm »
OK, I wrapped it up in a proper box and my Radon-device is now sending Syslog messages every 15min - I will probably change the interval to 30 or 60 minutes as the meter only changes once per hour
I added rechargeable battery and some logic to monitor battery level. Now the syslog looks like
2024-01-28 18:15:05.001 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (1-0) [80 10 12 11 82 1e 0d 03 6d 00 00 50 00 00 80 a5] 1-day=56, 7-day=59, longterm=59, uptime=4:03:13:30, volt=4180 / USB
2024-01-28 18:30:01.967 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (2-4) [80 10 12 11 82 1b 1c 03 6d 00 00 50 00 00 80 a5] 1-day=56, 7-day=59, longterm=59, uptime=4:03:28:27, volt=4196 / USB
2024-01-28 18:44:59.585 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (3-4) [80 10 12 11 82 19 2b 03 6d 00 00 50 00 00 80 a5] 1-day=56, 7-day=59, longterm=59, uptime=4:03:43:25, volt=4176 / USB
2024-01-28 18:59:57.865 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (4-4) [80 10 12 11 82 17 3a 03 6d 00 00 50 00 00 80 a5] 1-day=56, 7-day=59, longterm=59, uptime=4:03:58:23, volt=4178 / USB
2024-01-28 19:14:57.956 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (5-4) [80 10 12 11 82 17 0d 04 6d 00 00 50 00 00 80 a5] 1-day=55, 7-day=59, longterm=59, uptime=4:04:13:23, volt=4172 / BAT
2024-01-28 19:29:56.999 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (6-4) [80 10 12 11 82 16 1c 04 6d 00 00 50 00 00 80 a5] 1-day=55, 7-day=59, longterm=59, uptime=4:04:28:22, volt=4174 / BAT
2024-01-28 19:44:55.638 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (7-4) [80 10 12 11 82 15 2b 04 6d 00 00 50 00 00 80 a5] 1-day=55, 7-day=59, longterm=59, uptime=4:04:43:21, volt=4156 / BAT
2024-01-28 19:59:53.597 +01:00  10.7.14.152:4444        local0.info      [] RADONESP32: (8-4) [80 10 12 11 82 13 3a 04 6d 00 00 50 00 00 80 a5] 1-day=55, 7-day=59, longterm=59, uptime=4:04:58:19, volt=4168 / BAT
« Last Edit: January 28, 2024, 10:14:44 pm by cb831a »
The following users thanked this post: ChrisE
Offline FIB-Agent
« Reply #80 on: April 03, 2024, 05:04:57 am »
Just wanted to thank you all for your work on this project. I picked up a unit on eBay because it was cheap, and searched the model name + "hack" because I wanted better access to data, and this is pretty much the best kind of result one could hope to find from that. I'm just too early, I guess! Good luck.
Stupid question, but has anyone considered bypassing the computer and trying to read off the sensor directly?
Offline cb831a
« Reply #81 on: April 07, 2024, 04:33:52 pm »
Thanks, I'm happy you can use it.
The TTL 3.3V port in the Airthings device is very picky and even small leak currents in TX/RX makes the device stop counting and hence deliver to low numbers.
As you can see above my readings dropped to 0 whan I had a computer connected via a USB2TTL33 converter.
We never found out exactly what happened, but I found that the ESP32 serial port was "accepted" by the device and as I wanted to build a standalone WiFi device I followed that route.
My implementation has the serial port on ESP32 live/active approx. 20s 4 times an hour, and that may be why it does not affect the device.
PS: My battery lasts > 2months on one charge. If I only polled the device 2 or 1 times an hour the "lifespan" could probably be much longer. The device is only updated internally every minute, so polling once a minute should be fine.
« Last Edit: April 07, 2024, 04:40:57 pm by cb831a »
Offline djnebs
« Reply #82 on: April 13, 2024, 08:59:08 pm »
Personally, I've lost interest in this and moved on to the next project. Glad it helped those that took interest.
The sensor measurement had some concept of counting pulses (radioactive decay events?) on a GPIO pin. I suppose you could sample that signal directly, but without reversing the full firmware algorithm and calibration scheme, we don't know how to translate it into a meaningful metric.
« Last Edit: April 13, 2024, 09:00:55 pm by djnebs »
Offline medb
« Reply #83 on: September 06, 2024, 01:06:25 pm »
Fantastic work, this is exactly what I was looking for my radon meter.
I will post the code when I got it a little cleaned up.
Seems like it never got cleaned up :)
I wouldn't mind getting the code even if it's not cleaned up.
Offline cb831a
« Reply #84 on: September 09, 2024, 02:38:29 pm »
Thanks for the positive feedback - it's nice that someone can use the work we did.
I have attached the code I have been running for 8 month now  - could be cleaned up - but it works :-)
Please update the thread if you find errors or have improvements...!
I used PlatformIO as development platform, but any platform including AduinoIDE will do.
Claus
« Last Edit: September 09, 2024, 02:42:47 pm by cb831a »
The following users thanked this post: ChrisE, medb
Offline medb
« Reply #85 on: January 13, 2025, 09:23:00 pm »
Finalized my take on this and got the code into a Trigboard with some small modifications.
Got it nice and tidy by modeling and printing a box housing the Trigboard which snaps in place of instead of the battery lid.
The Trigboard is configured to read every 4h and uses the power from the same battery source as the sensor.
Once again many thanks for all the job done on this!
Offline ozman
« Reply #86 on: February 04, 2025, 03:14:29 am »
Incredible work reverse engineering this!
I stumbled on your work today while looking for a solution to an efficiency problem...
Background:
I recently installed an ERV in my crawlspace to reduce some numbers that were much too high.  Thankfully, it appears to be working!  Now I would like to make it efficient, only moving air when radon levels are high.
Dream:
I would like to be able to pull data from my Airthings Corentium, run the output through an ESP32 to trigger the ERV to reduce power or stop altogether, depending on the Airthings readings.
Other solutions:
Until I found your solution, the only other answer I could find was the $750 Radonova Robin (standalone Radon detector) whose output signal -- no screen, just a 1-10v output depending on Radon reading -- that can be translated to a motor control.
I would really like to try to build what you have made, but I could use a wiring diagram for your breadboard.   Would you be willing to draw one up and share it -- even if its on the back of a napkin!
Thanks!
