For low signal measurements I would like to make some shielded test-leads. The idea using microphone cable, as compared to f.e. RG316, is just the fact, that they are not only screened, but also twisted. And of course, having two cores, you only have one cable, maybe slightly larger in diameter, as opposed to having to use two when using RG316.
But I am not sure, what generally makes up a good test lead, CAT ratings aside, as those do not matter here. Of course there is mechanics (how thick, durable and flexible) a cable is, but those are rather easy to determine and personal preference.
Electrically however, there does not seem to be too much difference, just a quick shot:
Cicada:
Wire: 148 Ohm/km
Screen 30 Ohm/km
capacitance wire/wire(pf/1m) 120
capacitance wire/scree(pf/1m) 65
RG316
Wire 110 Ohm/km
capacitance wire/scree(pf/1m) 105
Insulationresistance is 1GOHm/km or above for both. Going larger in diameter would improve specs of the mic cable.
Now the capacitance would limit HF measurements, but that problem is shared by any shielded cable and is not planned as of yet anyway.
So would that be feasible or am I missing something very fundamental? I am aware of specialized cables like the ones made by ab-precision, but 100+ Euros just for the leads is a little over the top for me. Though I would wonder, what preciesly makes them worth the money.
Happy for any education and of course alternative ideas
Thanks
