Author Topic: Hakko 939 Replacement Case  (Read 2538 times)
Offline TorqueRangerTopic starter
« on: December 10, 2012, 09:28:55 pm »
well I tried to repair my busted up hakko 939 but some how alot fo the broken pieces went missing when I moved and I can't  seem to find a replacement case and yes I have googled and called many companies but no one has one in stock... So do I purchase a new iron or just find a project box that will fit it and use that?????
Here are a couple suggestions I think would work
So what do you guys think ?????
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
Re: Hakko 939 Replacement Case
« Reply #1 on: December 10, 2012, 11:04:14 pm »
I'd go for the one in extruded aluminum, it might be a bit small though.
« Reply #2 on: December 11, 2012, 12:39:27 am »
Also found this but this more of what I was looking for ..
http://www.hammondmfg.com/pdf/1456FH3.pdf
Offline nukie
