Author Topic: Part Identification  (Read 3472 times)
Offline Steve WayneTopic starter
Part Identification
« on: June 16, 2016, 10:17:18 pm »
Help in identifying this part would be greatly appreciated. I found this part in a box of diodes I inherited.  Its internal contacts are separated by about 300-400 µm.  I assume it’s somehow I, V, or R controlled.  If so, how do you test for its properties?   Thanks.
Offline wraper
  • Country: lv
Re: Part Identification
« Reply #1 on: June 16, 2016, 10:19:23 pm »
It's a reed switch.
The following users thanked this post: wagon
« Reply #2 on: June 16, 2016, 10:45:10 pm »
Thanks wraper.   How do you test for its properties?
« Reply #3 on: June 16, 2016, 10:48:50 pm »
Magnet
Offline wraper
  • Country: lv
« Reply #4 on: June 16, 2016, 11:11:32 pm »
google what it is
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #5 on: June 17, 2016, 02:28:26 am »
It's meant to be a magnetically operated switch.  I guess the properties you can test would be leakage when open (should be so small it makes it almost impossible to test) and resistance when closed with a magnet plus tempco on that resistance.  In general, I can't see tempco ever being much of a problem.  Reed switches are rated for current but you will have to guess what will be safe from the closed resistance since it isn't marked.
Found this:
https://www.digikey.com/Web%20Export/Supplier%20Content/Meder_374/PDF/MEDER_Parameters_of_Reed_Switch.pdf
Have You Been Triggered Today?
Offline ebclr
« Reply #6 on: June 17, 2016, 03:15:52 am »
« Reply #7 on: June 17, 2016, 04:17:54 am »
Thank you JoeN, ebclr & everyone.  Excellent information.
