Author Topic: Is it possible -15V/2A with MC33063?  (Read 1410 times)
Offline endorfin35+Topic starter
  • Country: tr
« on: November 25, 2023, 02:51:29 pm »
Hi everyone,
I'm not experienced in this matter. I want to generate -15V from +24V. I prepared the drawing attached. I'd like to hear your ideas.
1937157-0
Offline Terry Bites
Re: Is it possible -15V/2A with MC33063?
« Reply #1 on: November 25, 2023, 05:14:51 pm »
Yes.
You can make an inverting buck converter. See  9.2.1 and 8.2.1.2 in the datasheet. www.ti.com/lit/gpn/mc33063a
The calculations are simple but a bit tiedious. My advice, do the calculations in excel or other spreadsheet so you can tweak your design.
Or....
https://observablehq.com/@sharow/mc34063-inverting-conveter-calculator
The mc34063 is essentially the same as the mc33063, the only difference is an improved operating temperature range.
I asked our robot overloards gptchat: "Design an inverting buck converter with an MC33063. 24 volts input, -15 volts output"
Reply... https://chat.openai.com/share/9bb4bb18-c3e0-4b2a-b7c3-25e9f767c509 MFSOAB
The following users thanked this post: endorfin35+
  • Country: tr
« Reply #2 on: November 25, 2023, 06:40:49 pm »
The calculator was very useful. Thanks for this.
The thing that caught my attention is that for 2A current, 7.6A peak current occurs. That's a pretty high value.
On the board referenced, I see only one integrated circuit, one diode and one inductor for this task. It is not clear what the ic is. However, its structure looks simple.
« Last Edit: November 25, 2023, 06:42:39 pm by endorfin35+ »
