In appliance testing for work safety, the "Berührungsstrom (german) " (touch current) is measured via a 2k Resistor against earth to simulate the human body.
In reality, depending on some conditions like hand to hand or feet, or adult or child, it obviously varies a bit, but for own rough "over the thumb" calculations something like 1k Ohm is a pragmatical value to use.
And with skin, the voltage needed to push the first current through is a bit higher than what is needed to sustain the current flow.
Doing some math: 12V=1000 Ohms * x Amps
=>0,012 A
With 2000 Ohms obviously half, so 6mA.
And not to forget: If someone touches a live circuit, we talk about a voltage divider the human body presents, so not all current will flow through the human body, becaus according to Kirchhoffs Law it will divide proportionally to the conductivity of the current paths.
