Author Topic: Mini project on Circuit theory  (Read 2212 times)
Offline audioTopic starter
  • Country: in
« on: April 25, 2022, 04:10:30 pm »
Dear all,
I need mini project title for my 2 nd semester Circuit theory class.
We have been taught about DC Circuit analysis( basic laws, mesh analysis and nodal analysis) and AC analysis using phasor and steady state analysis. Our text is Alexander and sadiku.
We have been assigned mini project which could reveal learnt concepts.
You all can share your ideas. Thank you all.
Offline Doctorandus_P
Re: Mini project on Circuit theory
« Reply #1 on: April 25, 2022, 07:00:19 pm »
Take a book about opamps, and then think of some circuits to measure some non-ideal properties of opamps such as offset, bias and offset currents, GBWP, and build them on a breadboard.
  • Country: in
« Reply #2 on: April 26, 2022, 02:58:08 am »
It's purely r,l,c and sources.
Offline Etesla
« Reply #3 on: April 26, 2022, 03:08:43 am »
Make some filters and put audio through them to see how it makes the audio sound. Learn about input and output impedance when you try to listen to your output and hear absolutely nothing. Throw some transistors / diodes / opamps/ potentiometers in to start making guitar pedal circuits if you really wanna get fancy with it.
Offline tepalia02
  • Country: bd
« Reply #4 on: April 27, 2022, 11:04:24 am »
Did your teacher give you any idea about what type of projects you can choose? If you are only allowed to demonstrate what you've learnt so far, you can prove Ohm's law with a battery, a multimeter, and different values of resistors. You can also add LEDs to this project.
Have you studied the Hall effect? If yes, you can choose a Hall effect sensor based project. Those can be done with or without microcontroller depending on what components you are allowed to use.
  • Country: in
« Reply #5 on: April 27, 2022, 04:24:47 pm »
Purely rlc and sources
Offline Benta
« Reply #6 on: April 27, 2022, 07:22:14 pm »
A cool thing to analyse and present would be a classic 50s/60s electric guitar, eg, a Fender Stratocaster. There you have all the ingredients:
Inductance: the pickups, plus their inherent resistance and parasitic capacitance.
Resistance: volume control and amplifier input impedance.
Capacitance: tone controls and how they work.
The Stratocaster is especially interesting, as it has the option of paralleling two pickups giving an opportunity for further analysis.
  • Country: in
« Reply #7 on: April 28, 2022, 12:00:38 am »
Thank you sir
  • Country: in
« Reply #8 on: April 28, 2022, 12:01:18 am »
Our syllabus
UNIT I FUNDAMENTALS OF ELECTRICAL ENGINEERING 12
Fundamental concepts of dc and ac circuits, Steady state solution of DC circuits,
Circuit laws and their applications in solving problems
Introduction to AC Circuits, Sinusoidal steady state analysis, Power and Power factor,
Single phase and three phase balanced circuits.
UNIT II NETWORK THEOREMS FOR DC AND AC CIRCUITS 12
Source transformation, Superposition theorem, Thevenin’s& Norton’s theorems, Reciprocity
and Maximum power transfer theorem
UNIT III RESONANCE AND COUPLED CIRCUITS 12
Resonance - Series resonance - Parallel resonance, Variation of impedance with frequency -
Variation in current through and voltage across L and C with frequency, Bandwidth - Q factor
– Selectivity, Self-inductance - Mutual inductance - Dot rule - Coefficient of coupling -
Analysis of multi winding coupled circuits, Series, parallel connection of coupled inductors -
Single tuned and double tuned coupled circuits
UNIT IV TRANSIENT ANALYSIS 12
Natural response - Forced response Transient response of RC, RL and RLC circuits to
excitation by step signal, impulse signal and exponential sources Complete response of RC,
RL and RLC circuits to sinusoidal excitation
UNIT V TWO PORT NETWORKS 12
Two port networks, Z parameters, Y parameters, Transmission (ABCD) parameters, Hybrid(H)
parameters Interconnection of two port networks
  • Country: in
« Reply #9 on: April 28, 2022, 12:29:12 pm »
Dear all,
Request you all to share what are the possible mini project that can be done by the way of my syllabus.
It will be useful for my academics.
Thank you all..
Offline Picuino
    • Picuino website
« Reply #10 on: April 28, 2022, 01:32:07 pm »
You can make tests to find out the parameters of a real transformer or a real DC motor.
From the simplest parameters to the most complex parameters.
Offline Grandchuck
« Reply #11 on: April 28, 2022, 09:03:02 pm »
One possibility is a device for measuring the internal impedance of cells and batteries.
  • Country: in
« Reply #12 on: April 28, 2022, 11:51:12 pm »
How to measure internal resistance of a cell?????
Offline free_electron
    • SiliconValleyGarage
« Reply #13 on: April 29, 2022, 12:29:55 am »
behavior of a real copper coil under temperature...
Offline Ground_Loop
« Reply #14 on: April 30, 2022, 06:28:04 pm »
Demonstrate maximum power transfer with complex impedances.
There's no point getting old if you don't have stories.
Offline Grandchuck
« Reply #15 on: April 30, 2022, 07:49:53 pm »
