Author Topic: Missing pin 1 mark  (Read 841 times)
Offline RajTopic starter
  • Country: in
  • Self taught, experimenter, noob(ish)
Missing pin 1 mark
« on: June 23, 2021, 07:41:14 am »
Did I get a fake from China?
The lm75 I've ordered lacks pin 1 marking
Good thing, I've got a lot of them, so i can burn one of them testing the pinout
I'm guessing, it's the down right one in the picture
The tech drawing of the datasheet clearly shows a pin one mark
« Last Edit: June 23, 2021, 07:48:04 am by Raj »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Missing pin 1 mark
« Reply #1 on: June 23, 2021, 07:55:52 am »
Check if one side of the package may be chamfered. That is the your pin 1 side.
Datasheet also mentions this though, yours must be old.
https://www.nxp.com/docs/en/data-sheet/LM75A.pdf
Also, your screenshot is of the TSSOP8, and it seems you actually have the SO8.
« Last Edit: June 23, 2021, 07:57:37 am by Jeroen3 »
The following users thanked this post: Raj
  • Country: in
« Reply #2 on: June 23, 2021, 08:03:30 am »
yes it is. now there's some doubt gone.
Strange new fangled way of marking pin 1 though.
And indeed... got the package type mixed up while reading the datasheet
« Last Edit: June 23, 2021, 08:06:50 am by Raj »
Offline tooki
« Reply #3 on: June 23, 2021, 12:40:51 pm »
Not newfangled at all. It’s one of the established methods. If anything, one that’s falling out of favor as the packages get thinner, leaving no height to be chamfered.
Offline amyk
« Reply #4 on: June 23, 2021, 01:28:02 pm »
With the text in normal orientation I don't think I've ever seen pin 1 on an inline package be anything but the bottom left corner.
The following users thanked this post: tooki, Raj
Offline gcewing
« Reply #5 on: June 25, 2021, 09:33:49 am »
The chamfer might be designed for detection by machines.
Offline tooki
« Reply #6 on: June 25, 2021, 10:46:32 am »
Doubtful. This marking type was never universal enough to serve that purpose. Orientation-sensitive SMD components are always oriented the same way in the reel.
Offline redben
« Reply #7 on: June 25, 2021, 12:34:29 pm »
Agreed, I have not seen any new components from major manufacturer using this chamfer solution.
