That was just the solution middle part of the problem, detecting the missing pulse and triggering on it. Since it's reversed logic it's much easier to handle.
The full problem was to start this circuit only on key press (a second input, driven low) and to also have it shut off after one second or so of being activated.
I kind of achieved this goal with a few extra parts (a transistor, a diode, a capacitor, one resistor) but it is very sensitive to the duration and delay of the user input. I'm going the uC route now, it was only an exercise. If anyone is curios to take over I can post the new simulation values and schematic.
The goal was the following: the simple coffee machine I described in another post has a limitation that I have seen on a lot of these 'dumbed' devices. You can not start the coffee preparation unless the water is heated.
While the heater is on the LED is flashing once every two seconds (50%). After the boiler has reached the required temperature the LED stays on and you can press the coffee button. This process takes ~70 seconds at first start so it's really annoying if you want to make a coffee and then forget about it. You have to wait until the flashing is finished to prepare the poison.
Another use of the same LED is to show that it is out of water. In this case the led flashes at about 5 times per second until the water tank is refilled and replaced, after which it starts the heating process.
I wanted the simplest two or three transistor circuit that could accomplish this but I don't really think it is doable in a reliable way.
This is just warming up to tackle the big coffee machine - a Saeco Talea Giro - which I intend to enhance with some features and overrides. The complexity is a bit high though: 48 I/Os (digital, analog, capacitive), serial I/O, IrDa, huge flash memory and a lot of unknowns. It's probably easier to piggyback the existing board and override the controls.
