Author Topic: problems with pcb ironing method  (Read 15651 times)
Offline KerryW
Re: problems with pcb ironing method
« Reply #25 on: July 12, 2015, 01:57:12 pm »
Here's what I do:
Print to glossy magazine paper  Use highext density printing available.  Don't touch surface of paper.
Clean copper qith 00 steel wool, then wash thoroughly.  Don;t touch copper.
Transfer using laminator (preferred) or iron.
Soak paper off with water.  Rub with fingers and/or toothbrush.
Inspect.  Remove any printing from magazine paper with IPA.  Touch up any missing toner with RED Sharpie.
Etch.
Drill.
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
